sorry for the double post I kind of screwed that up but I'm not very phone friendly and that's all I have to get online with sorry
 anyway my idea that just popped into my head is that I was replacing an O2 sensor on my girlfriend's right hand drive jeep and I was thinking you know the air-fuel mixture is monitored by O2 sensors that I don't know about newer bikes but my bike has no sensor that does that but I remember when I was building up an scca race car out of a Ford Focus RS that after we got so much stuff done to monitor the air fuel mixture ratio we bought a f meter and all it did was drill a hole in the exhaust weld the tap it on and then stick the little sensor in and it ran straight to the gauge and it would have a range that was telling you if you're running rich efficient or lean and it was a standalone system that was very small the gauge was fairly inexpensive.
 so having the flat spot in my throttle which was the original thread I decided join the form for is that would it be practical to use one of the stand alone air fuel mixture gauges in a motorcycle since that it monitors the exhaust gas itself in determines if there's excess or not enough of certain experiments into the exhaust stream whether it's running rich or lean because these gauges can be had for less than $30 all they do is hook up straight to the battery and a cable runs down to where you put it into the exhaust which I thought maybe right before the muffler would be a good place to put it in and monitor the air-fuel mixture at all points throughout the RPM range on a car why wouldn't they work for motorcycles?
 this might be unnecessary for daily driving but it may be an appropriate tool to diagnose lean or Rich conditions just by hooking it up driving the bike and watching the gauge and then after you're done if you don't wish to keep the gauge on the bike you could always just remove it and plug the tappet hole in the exhaust.
 if nobody knows what I'm talking about just Google air fuel mixture gauges and it will pop up they're just a little set of green red and yellow lights that go back and forth and it gives you a reading if you're rich lean or ideal.
 my basic training fight on this idea was that if you're having issues with your motorcycle such as I am with a flat spot at 68000 RPM it would tell you whether or not you're rich or lean doesn't mean that it would take the accuracy of having the synchronization of carburetor setup properly but it would give you an idea of the overall running condition and possibly a direction to start heading during Diagnostics or fiddling to get performance or reliability or drivability out of your motorcycle.
 maybe this is a dumb idea and if it is somebody slap me because I don't know girlfriend does that a lot but it was just a thought and I would like some input on whether or not it would be a good or bad or meaningless task to accomplish.
 but I'll go ahead and apologize now for double post excessive threads and really long posts because I use text to talk and I don't realize how long my texts are being by the time I post them so I apologize in advance but any ideas on this matter would be greatly appreciated like I said I'm new to motorcycles as far as owning and working on my own even though I've written motorcycles a long time my daddy always took care of it when I was little but now I'm 33 and bought my first street bike just a couple of weeks ago so 15 years out of the loop and now with a new bike and the want to fiddle and Tinker has all these ideas racing through my head.
 anyway thanks
 Mike Berry
